- Joined
- Apr 26, 2016
- Messages
- 1,291
- Reaction score
- 305
Wait, you have a 5.2 engine?
I am so busted,lol.
Good thing I prefaced my story in the very first sentence, to 8.0 !
And ended it with mentioning tight splits.
If it's passing power you need, um, 3.07s are not the right gears.
75mph will be 2929 in loc up. Kicking it down into1.54 second, the Rs will jump to 4737. This is way past the power peak, and so far into never-never land for a stock-cam teener that the car will do not much more than roar.
Perhaps you could look at this from a different angle. At what roadspeed do you want to begin your passing maneuver? and at what rpm should your teener be, to expedite this?
Lets say you wanted to begin the pass at 70mph, and the engine makes peak power at 3900. And you want that A999 to kick down one gear,into 1.54second, and you want to complete the pass at 80mph.
Firstly, determine the maximum rpm, say 4200, and the TC slip is say 5%
The gear ratio for this is;
(80mphx1056constant x1.54second)/(83rollout x4200/1.05slip)=2.55 .. So 2.45s are the closest ratio.
These will get you 70 at 3528 and 80 at 4032; perhaps a little on the low side, but the next ratio, the 2.73s are 11% higher so; 3931 and 4493, which IMO is too far past a 3900 peak.
Now, if you were to use the A904, and the tranny downshifted into 1.45second, then the right ratio would be
(80x1056x1.45)/(83x4200/1.05)= 2.71s, so 2.73s would be the ones. These will get you to 70mph at 3700 and 80 at 4230; very well centered around the 3900 power peak.
I like the 904/2.73s. Drove many many Mopes with these. Your rpm at 75 in Drive,will be about 2600 plus slip perhaps up to 2730. I would install a TC in the range of 2600 to 2800. Your car will have a completely different personality.
If you lived next door, I would loan you these items for a test-run,lol.
Be advised;
I guessed at the 3900 power peak. Yours might be lower. Or higher. IDK. Find out. Then just sub in a number that is about 5% higher, for your top speed rpm. The formula in blue will work for any numbers you sub into the right spot. I even guessed at the tire rollout of 83 inches. This is for a tire that is 26.4 tall, or a 205/70-15.
I am so busted,lol.
Be advised;
