NOS Mirada (maybe Cordoba) wheel well lip trip mouldings
M_Body_Coupe
Windsor, ON, Canada
I have 3 NOS pieces of the wheel well trim / mouldings that are anodized aluminum pieces!! How often do you find a nearly full NOS set of these??? Asking price is $275, make me an offer otherwise...
These were used on the Dodge Mirada and Cordoba 1980s model Chrysler cars, so Mopar J-body vehicles. 2 of the 3 are still in the shrink wrap, 3rd is not, and the photos show the finish. These are NOS, the markings you see in the close-up photo is the left over coating / adhesive from the shrink wrap.
The Mopar parts are:
1) 04175130
2) 04175131
3) 04175132 (see 'bad news' below...)
So what's the bad news: well, one of the pieces has a dent, see the picture. It's a sharp dent, one spot only, therefore could be removed. Unless you are a master aluminum handler you probably will NOT be able to completely remove the marking...so do not expect a miracle fix, but, you can make it look nearly spotless.
Looking to SELL or trade for Mopar W2 stuff (rocker arms, intake manifold), 360 block (roller, early casting '71-'74, or an otherwise known good block - sonic tested maybe?) or small block stroker parts (NEW) only.
