PARTS AVAILABLE
CM360
Are all the front suspension parts, including all the bushings, available readily for the F body?
Pretty much. The exception is the t-bar end bushings and the sway bar center link assy's. I believe the actual rubber parts are available, not the metal part itself. I think the only thing available for t-bar ends are urethane and you need to reuse the bushing shell and center sleeve, same for the t-bar pivot bushings.
