Spare parts for oil leakage
On the fluid cooler line and fitting. I think you said it still leaks a bit(?)
Make sure the brass fitting isn't cracked. Very rare but I've seen it a couple times. Also inspect that the tube seat on the fitting is not damaged and that the inverted flare on the tube isn't marred or cracked in any way, if not already done.
Kind of a dumb question, and don't mean to doubt anybody but, on the shift shaft seal, it didn't get put in upside down by accident? It can happen although I've never done it far as anyone else knows, LOL.
1337m4723
Hanover Germany
You can see the slightly red color on the fitting on the pictures in a previous post. But I think it is just really a little bit.
I guess the main leaks are the pan gasket and the shift shaft sealing...
I am pretty sure the shift shaft sealing sits in the correct direction. I try to upload a (bad) picture. But still I am not sure if it was renewed at all or if it was renewed without cleaning the shift shaft...
