jasperjacko
- Joined
- Dec 4, 2011
- Messages
- 1,671
- Reaction score
- 251
Nice find, Congrats!
My car looked just like yours when I got it,put a set of rims on it black out the grille and ditch those wheel lip mouldings,I'm sure the wife will like it even more.
That is a nice ride 80aspen!
So Captain...how did it go today? Boss let ya out early?
Don't forget you'll need to adjust the valve lash on the slant when you do a tune up. They are solid lifters, .010" intake and .020" on the exhaust valves.
Real easy, I used to have a '72 Satellite with a slant. All you need is a 3/8" box wrench and feeler gauges. Get the engine warmed up well. Remove the valve cover, turn down the idle to around 500rpm. Insert the gauge between the valve stem and rocker. If needed, open or close the lash...you'll get a feel and you'll be able to feel the engine get a miss if you go to tight, and the valve will get noisy if you go to loose. Don't forget the two intake valves are next to each other in the center (3 and 4). Some like to adjust with the engine off and turn it by hand. I like it running so the valves are the same temperature at all times. Get a more accurate setting that way. You may get a skinned knuckle or two. Part of the cost of owning a slant!
