Mn mopar
Ok so im having issues with my 1980 mirada, after driving id say 45 minuets to an hour or so under acceleration over about 10-15% throttle car acts like im almost out of gas ( tank does not have baffles) but i know i have gas in the tank as the gage works, or if it is a hot and humid day will happen sooner then that, now im not sure if im dealing with vapor lock or something else, fyi before i started driving the car i replaced all fuel lines the pump the filter had the carb rebuilt new sending unit and cleaned the inside of the tank so now im coming to you guys yet again lol, one question is if it is vapor lock can i add a low pressure electronic fuel pump by the tank and keep running the mechanical fuel pump or just ditch the mechanical one and make a delete plate for that?
