WANTED Wanted in N/E Ohio
Lightning II
Augusta, GA
Just checked Car-part.com
you’ve got about 4 within a hundred miles under a hundred bucks.
the closest is in Harmony, PA at Rusty Hook Auto Salvage
412-657-9522 ext. 3
It’s $75 and change for it.
singin sam
Mantua,Ohio
412-657-9522 ext. 3
My problem is getting someone to drive me there.,
Thanks for the lookout.
Hayzoos
Revloc, PA
I suggest you look for a non-lockup converter and transmission. I had a '79 LeBaron SuperSix which I had a lockup converter trans. I could not find a good lockup converter trans to put in it. I finally found a late 60's Valiant non-lockup converter trans which gave me no troubles. I had to also get the shift linkage brackets, I had a column shifter.
