Well This Sucks!!
volare 1977
It is what it is. Pretty much normal for that time period. Still love those old things defects and all.
exactly ... what was it Fix Or Repair Daily ...
but I'm sure we've been down that road before.
And just how have you adjusted to retirement Aspen500??
I could set the alarm and give you a wakeup call about 4 am if you miss it..
Ele115
Tampa FL
I would have two options if I had this right now. My die grinder and a 5 inch tapered (flame shaped tip) burr or the plasma cutter. I think the plasma cutter would fit in there, but kind of may get messy. Die grinder would be no more than 45 seconds per bolt. Either of the two should do nicely. You need new bolts no matter what. Grade 8 bolts should be fine unless you plan on doing wheel stands or something. I say two options, but the blue wrench is the same thing as the plasma cutter really so you could say three options. Same exact procedure, different tool.
Remow2112
How much patience do you have? Get in there with an angle grinder and a carbide bit. Maybe 5 minutes a bolt.
Reggie
Maryland
Good old sawzall did the trick.
Reggie
Maryland
Regarding the sawzall - I used a 6" carbide grit blade (an old one at that) and it cut through the bolt like butter.
