Wtb proportioning valve
DaneBisel
New Member
Looking for a proportioning valve that will work on a disc brake conversion. I am using the f m j spindle set up and looking for a stock valve that will work. Please email me I you have one. Im4dux@yahoo.com. Thank you
ramenth
Beaver Dams, NY
Why? Just wondering.
You can buy an aftermarket adjustable one cheap enough, you won't have years of sludged brake fluid in it, no worries about deteriorated o-rings, and it'll allow you to dial in your bias.
NoCar340
Upper MI
If you're going to use a factory prop valve use one from a disc-brake version of the type of car you're modifying, not the brake setup. Proportioning is about load bias as well as piston size, but even then the factory valve is a compromise: the prop valve from a Hemi Charger is the same one as used in a same-year Slant Six Coronet wagon if both have disc brakes.
