Instrument panel
Gunnar Schroder
Norway and Sweden
Hi all of you members from an update from Scandinavia.
My G22 1978 is slowly coming along during my slow restauration. Time does not permit me many days off to carry on.
Having said that I had trouble with the instrument panel not working as it should. The voltage regulator packed in (what I thought!) as the fuel guage an temperatur
stopped working. Well, I took the minor printed circuit board out and put my glasses on. Checking everything over I found that the pins for the connector was not up
to my standard. They wer loose and flimsy. The soldering Iron came in handy and a quick fix soldering them carefully to the copper did the trick. A voltmeter told me
that they were on and off when checking the resistance.
Now it is even better than new as I put it back and lamps and all worked. I have changed all bulbs to LED by the way as once dismantled a few minutes extra to change
them and the holder.
By the way: I have a very good 8 1/4" rear axel that I intend to use. Checking over the spares list I have told me this axel has a different mounting plate.
Part numbers: Plate 8 1/4" axel 3845 128-9
Any idea where to get those or may I modify the one from 7 1/4"??
A good pair of seconhand plates would come in handy as the rest is dead easy to get hold of.
Take good care of each others and safe driving to all of you.
Best Wishes from Norway
Gunnar
You will also need the spring brackets as the axle tubes would be narrower on your 7 1/4.
The backing plate for the 8 1/4 is the same as the 80s 7 1/4 and most other models from the 70s and trucks upto at least 92/93 so that should make them easier to find.
You just need to know do you want to use 10" or 11" brakes?
Gunnar Schroder
Norway and Sweden
I have not yet made up my mind but I think 11" brakes may be the best. Pretty sure the 7 1/4" axel has 10". I will sort everything out this weekend. Spring brackets no problem over here and I would guess they have to be wider due to 1" wider axel. Thanks for your tip regarding backing plate. I will have a chat with the one I bought the axel from as well as another friend in western Norway who has the same car (or shall I say had!) as mine.
If I recall right a Dodge Diplomat station wagon
All F/M/J cars used the same rear axle dimensions: flange to flange is 54.34" and perch center to center 44.46". It should drop right in if it's from an M wagon.
The 80s M body axles were 1" wider then the older ones but spring perche to spring perch is the same.
dm330
Salem, OH
So I'm having my 8 1/4 installed next week and the shop doing the work will use the backing plates off the 7 1/4. The backing plates on my 88 7 1/4 can utilize either the 10in or 11in brakes? If that's the case I'll keep that in mind the next time I need the rear brakes replaced and go with the 11's.
Gunnar Schroder
Norway and Sweden
I have learned the same from various sources. Good to hear and hopefully another member here have a set. Keep your fingers crossed.
Take care and safe driving.
Gunnar
dm330
Salem, OH
From what I've read I was under the impression I'd have to settle for the 10's from the 7 1/4 since. He already had everything in shop so I won't bother him about it at this point. We were just waiting on the leaf springs and that was it for the back.
The way we drive these rare birds 10" is more than enough. I will see if I simply move the brakes over to the 8 1/4".
I've got a complete set of 11x2.5" rear drums. Backing plates, drums, cylinders and hardware. Practically new. Pulled it off for a disc brake swap. It's yours if you want it, but shipping would probably be killer.
Gunnar Schroder
Norway and Sweden
I guess so but you may ask for a quote from Federal Express. I have found them very serviceminded and quick off the mark. RockAuto use them and from them I have had some spares stocked up ready for the weather to warm up. Then it is easier to work outside.Here is our Aspen taken in Germany on our way to Spain for holiday. 2800 km one way. I miss that car but the G22 will do the same job apart from missing AC.
The backing plates will fit the axke but they are specific to 10 or 11" brakes it's not one size fits all.
When I did the 8 1/4 swap I pulled the axle shafts and left the backing plates with the car so I didn't have to mess with brakes and bolted them onto the different axle.
I only have one car with 11" brakes. Never had a problem with 10s.
