Stuck thermostat?
MoparDan
Daytona Beach, FL
Engine was overheating, while sitting in a long line...anti freeze was pouring out the overflow bottle, like the thermostat was sticking I just replaced the thermostat about a month ago, is the thermostat defective or something else?
69-
Germany
Hard to say.
You can test the thermostat in a pot with boiling water, it has to fully open.
69-
Germany
Take the thermostat out, it will be closed. Put it in a pot with boiling water and it will open. You will see the closing plate to open.
69-
Germany
If it does open, there's most likely lots of dirt, grime and such in the cooling system.
I'd then suggest to flush the whole system.
Else it could (I'd say unlikely) be the water pump. If you take the belt off, the fan (it is connected to the impeller inside) should turn very easily.
69-
Germany
Or you have a visco coupled fan, then it should have some resistance while the belt is on. Visco coupling is heat actuated and fully turns the fan only when hot. Water pump is meanwhile always turned by the belt.
69-
Germany
You from Daytona beach? Man, I completely missed taking that into account when I was at the Rolex 24h in January... o_O
MoparDan
Daytona Beach, FL
As soon as I get my sockets back tonight I'll do that...
Yah, lived here about 9 years now
MoparDan
Daytona Beach, FL
My guesses are air trapped in the system... or your fan clutch is junk and you legitimately overheated
MoparDan
Daytona Beach, FL
The good news is the oil isn't milky so that's a good sign at least. I found it strange that the temperature gauge was climbing since it pretty much doesn't move anymore, that's when I popped the hood and saw a ton of coolant pouring out the bottle like the last time it stuck
Yeah I'm going with bad fan clutch. The rest of my parts cannon theory of automotive repair would go like this: Bad radiator cap. Then clogged radiator. Then bad water pump. Then time for new engine.
volare 1977
It wouldn`t surprise me if a new t stat was bad. Check for coolant flow. I would replace the radiator cap first.
Ele115
Tampa FL
Go through everything, not just the pump. Check it all.
If it hasn't been maintained well it may need more than one thing. Water pump, fan clutch, a flush. Gooped up radiator. Test your fan clutch. It's been hot in Florida and everywhere else. You need good airflow and coolant flow.
If you are running straight water, you're going to be needing some big repairs just down the road. Frost plugs, heater core, head gaskets etc.
Ele115
Tampa FL
You're not running water are you?
This is a biggun here. Natures Dexcool.....LOL
Have the guy open up the water pump and put a pic of it on here. Curious how it looks and if it's the original one. Thx
Nature's Dexcool, LMFAO. I'm stealing that.
