Fuel lock ring kits
Ash_Whole
Vancouver BC
i replaced the fuel sender, spectra premium. now what a shock, the sender leaks. what is a good lock ring kit that actually fits the OEM tank and the Oring seals?
well $40 is expensive, but less than the gas i will be leaking over time i guess.
thanks
I either use the old original lock ring if still good or find a mopar NOS one when I can. I also use a new mopar seal too. I had issues with the aftermarket rings being flimsy. I tried to tighten a leaky aftermarket lock ring and got 5 gallons of gas on the garage floor. What year are you working with?
It's the same problem with older cars. Had much trouble with an aftermarket lock ring on the gas tank of my A100 from 69.
Bad Chinese crap
I ended up reusing the original one.
These are for the early cars I bet. Hoppy may have dome for the later cars. You would just need to ask.
