FOR SALE Structural Metal From a '79 Coupe
slant six
I have some parts left from a '79 Volare' Coupe that I have mostly Parted.
If anyone is interested in these parts please respond, otherwise They will go to the scrap pile, and get cut with no regard for saving the parts.
I can remove parts properly with a minimal amount of damage using a spot weld cutter for you.
All are located in 15642, PA ~ 5 Min from I76, Exit 67 in PA. Can bring large pieces to shows that I usually attend (Mason Dixon Dragway in May 2026, Albion, PA in June 2026, Carlisle in July 2026.
Front Core support $100
Solid, no smashes or collisions, some rot near spot welds under the batt. tray area and also near the right side front under the overflow can / vapor canister area. I feel that if you can work with metal and a mig welder / grinder these are easy repairs. Part is not perfect but good and usable. more pictures upon request.
Left and Right Inner Fenders $40 Each - I cut these from the frame rail so there is ~1/2" of metal missing where they were welded from the factory that will need replaced.
RIGHT:
LEFT:
Front Floor Section $100.
It is not perfect. There is some rust above the rails, but is 92% solid.
I would be cutting all the spotwelds to remove this piece.
If I did not list it here, that is because it is sold or rusty garbage.
Thank you.
Might be interested in that front core support if you can bring it to Carlisle in July - does it come with the radiator mounting brackets intact?
The radiator mounts are stock and not chopped up or cut in any way is that what you mean?
Can provide more / better pictures of that area. Can bring to carlisle as said before. and If you Come from Chicago you are likely driving right psst my house on interstate unless you take I80 on PA.
Let me know what you are thinking.
More pictures / Detail:
https://flic.kr/p/2rRnqk4]20260111_165851[/url] by https://www.flickr.com/photos/149826863@N07/]Hyperpack[/url], on Flickr
https://flic.kr/p/2rRnqjn]20260111_165855[/url] by https://www.flickr.com/photos/149826863@N07/]Hyperpack[/url], on Flickr
https://flic.kr/p/2rRoKb6]20260111_165905[/url] by https://www.flickr.com/photos/149826863@N07/]Hyperpack[/url], on Flickr
https://flic.kr/p/2rRoKap]20260111_165910[/url] by https://www.flickr.com/photos/149826863@N07/]Hyperpack[/url], on Flickr
https://flic.kr/p/2rRojNC]20260111_165923[/url] by https://www.flickr.com/photos/149826863@N07/]Hyperpack[/url], on Flickr
https://flic.kr/p/2rRnqhi]20260111_165918[/url] by https://www.flickr.com/photos/149826863@N07/]Hyperpack[/url], on Flickr
https://flic.kr/p/2rRojLy]20260111_165939[/url] by https://www.flickr.com/photos/149826863@N07/]Hyperpack[/url], on Flickr
https://flic.kr/p/2rRnqfQ]20260111_165933[/url] by https://www.flickr.com/photos/149826863@N07/]Hyperpack[/url], on Flickr
https://flic.kr/p/2rRpc2L]20260111_165943[/url] by https://www.flickr.com/photos/149826863@N07/]Hyperpack[/url], on Flickr
https://flic.kr/p/2rRhMMP]20260111_165950[/url] by https://www.flickr.com/photos/149826863@N07/]Hyperpack[/url], on Flickr
https://flic.kr/p/2rRnqe2]20260111_170005[/url] by https://www.flickr.com/photos/149826863@N07/]Hyperpack[/url], on Flickr
https://flic.kr/p/2rRhMMt]20260111_170009[/url] by https://www.flickr.com/photos/149826863@N07/]Hyperpack[/url], on Flickr
https://flic.kr/p/2rRoK8a]20260111_170015[/url] by https://www.flickr.com/photos/149826863@N07/]Hyperpack[/url], on Flickr
https://flic.kr/p/2rRhMLS]20260111_170019[/url] by https://www.flickr.com/photos/149826863@N07/]Hyperpack[/url], on Flickr
