Lean burn control modules
prowler
santa clara CA
I 'd like to hear from those who've had the lean burn control module fail and what symptoms you experienced along the way if any. The earlier versions, 76-80 had electrical fail issues, and I know in the 80's they seemed to have sorted them out. I had recently gone through my 77 LeBaron and it has never run better. I don't use the car regularly but do leave it on a battery tender. I drove the car 2 weeks ago and it ran great! Last week I took it to the grocery store and the moment I got on the road, I could tell something was amiss. Flat throttle, very low power and if I tried to accelerate it bogged badly. Made it to the store but on the way home it seemed worse. I had to play with the gas pedal and keep speeds very low. I made a right turn and the engine died out. I coasted to the curb, popped the hood and looked down the carb throat. I thought it was a fuel problem but the entire system was new. A couple of mins later the car fired up but was still no where near correct. Made it home,...barely! It appeared to be in a "limp" mode but still not sure. Car has been in the family since new and have had these modules fail in the past. Last one I got several years ago was from Rock Auto as a reman. I'm still not 100% sure it's the module and am checking fuel press and carb but from what I remember this resembles past module failure. Thanks.....Mike
I'm still running the lean burn while I build a 360 to replace the whole thing.
If you have a service manual for your year, go through the diagnostic procedures.
There are a lot of things to change/fix before you get to replacing the computer module.
In my case, there was still more wrong even after replacing the computer.
when my 79 one went it started pinging badly. Like AMC Diplomat said check the service manual, there is a procedure to test them in there that doesn't require any special equipment.
The 80s computers are more reliable, I've never had one fail. But there are more components to it so at some point it ends up being easier to replace it with a normal electronic ignition then chasing down continuous problems.
Yes,... there are check procedures for components. But I know from past problems, when you're driving and the engine flat dies out, there's not much that'll do that except the ECM. Since new, probably gone through 5 ECM's including the one on car now. The ECMs are getting a bit more difficult to locate. In the past, a repair company would find the failed electrical component, replace it, and consider the ECM re-maned. There's a couple of companies out their that claim to go through the ECM all the way around and replace or update known components that have a track record of past failures. Of course the price is more as well. Prier to a week ago the car with all the work I'd put into it, had never ran better in the last 25 years.
A bad vacuum leak would do a lot of what you're describing. On a 40+ year old car they can be a series of cracks on a vaccum line, quite innocuous.
Early on with my car, I had a bad choke thermostat and a bad choke pull off, so the choke would slam shut while stopped, killing the car. I ended up driving home with the air cleaner off and a screwdriver down the carburetor holding the choke open
It could still be a fueling issue. Do you have a fuel filter with the side outlet for the return line? If so, pinch kink that line in half, secure it with a ziptie and take it for a drive.
That side nipple is a vapor bleed, to help reduce the chance of vapor lock. There is, or should be, a .060" orifice in the nipple. If it's missing, like in some cut rate filters, it could cause problems. With the orifice, very little to no liquid fuel will go back to the tank.
The original ESA modules do have a limp mode where if the control board fails it basically just acts like a standard ignition module but running on locked base timing. The dual pickup distributors also have a failsafe where if the run coil fails it will time off the start coil which is significantly retarded. That doesn't seem quite like what you have going on though, it sounds more like a fuel issue.
Check your timing with a light and just see where it's at baseline and if it moves at all when you hold some RPM to it before you look into the module, it could also be one of the sensors like the closed throttle switch, temp sensor, knock sensor, etc.
Regardless, the op's symptoms sound very close to vapor lock. When I was a kid kinking that side line coming off of the filter fixed a horrible vapor locking condition and got me home. He should try this at least to aid in troubleshooting.
Thanks for the replies. After checking fuel system, looks more like it be may be in that area. I hooked up a fuel press gauge and needle was all over the place. Raised rpm and dropped to around 3lbs. Everything had previously been gone through or replaced. I couldn't help notice when I removed the fu-filter there was hardly any fuel in it. The pump is supposed to have a check in it to prevent drain back. Probably why I've had to crank if car sits for a week.
Next I found I had a gnarly vibration that felt like a bearing in the alt so I removed belts,...made no difference. The vib comes on when I hold engine steady at higher rpm's while watching press gauge needle move around. I feel like either the pump is starving or something might be mechanically wrong with it. Concerned about the vibration, so I'll probably pull the pump and inspect.
If you're still running the original carburetor, I wonder if you're having an issue with the bowl vent solenoid
Are you in park when you're doing that? Could be you're beating up the torque converter
Found a very loose air pump belt that seemed to calm down vibration. 2 bbl carb, very easy. When I hold
a high RPM and observe pressure gauge, needle fluctuates from 4lbs down to 2lbs the back up to 4lbs.
I'm assuming that the carb a higher RPM's is dumping more fuel and the pump is responding.
I checked torque convert as I suspected it may have had counter weights. I was wrong. At this
point I haven't driven it since, but it enfine sounds OK. Test drive coming up but I'm still suspecting
the ECM.
