Strange "engine died" issue after left turn form dead stop
69-
Germany
Hey guys'n'gals,
My LeBaron has been a heck of a super dependable and reliable ride since 2018. Never died on me or left me stranded for more than 15k miles for the last 6 years.
But now, there are issues.
First. Yesterday I wanted to pick up the LeBaron to drive to my Mom (in hospital ATM) with my wife. Go to storage, turn key, wait for fuel to arrive at carb and run. That was my expection.
But, no run. And no time to diagnose (first: Mom at hospital). Later I re-checked and hat a strong, blue spark. Good. But no fuel in Carb. Not good. Likely culprit: fuel pump (hoses + filter have been replaced last year, they cracked with only like 4 years old...).
This morning, early, because again Mom at the hospital and a local meet nearby I just linked a electric fuel pump instead of the mechanical, hooked the wires & hoses - turn key and run. Very good. :)
Ran just fine to the hospital and the meet (we had like 93F today), no heat issues, no run issues, all good and perfect. Even long wait-in-line, no problem. As usual :)
On my return trip, the engine started perfectly, idled well and ran good on the first like 4 miles. Then, from a dead stop I had to turn left. Did that, it accelerated fine (no race start; well, that's impossible anyway :) ) but just a couple 100 yards on the road it kind of stumbled, hesitated, no power, it felt like not enough fuel. So, while on the road (no emergency stop possible), turn in neutral, try a couple shots of gas. Dead. Engine just died. Luckily, while still rolling and me seeking a spot to park (still none), I tried to start it again. Turn key - it came immediately to life, no stumble, hesitation - just fine.
While I was driving kind of careful, listening to anything abnormal (none) it ran just fine. Until I did it again: Dead stop, start with a left turn. Stumble, Hesitation, Died. Again, neutral, start, ran.
SO. To come home I tried to figure a way home with only right turns, no left turns. I had to more left turns and was anxious, if I'd be the culprit of the next big traffic jam in city (only one lane, no side of the road space). But going very slowly through the left turns I managed to safely arrive home.
NOW, I'm kind of at a loss about what this could be.
First thing, I'll re-check the ignition, to rule this out. On the road I quick-checked some connectors (e.g. new fuel pump), which are fine and not moving. Then I'll check the carb (a Edelbrock 1406, it's a 4bbl 318 in it, with just 62k miles on it).
Any ideas? Suggestions?
Oh, and pictures of the meeting are here Car Meetings / 2026 08 Straßenbahnmuseum Wehmingen | gecius.de Gallery :)
What it is and what I think it is - could be not the same thing.
What I think it is is a stopped up fuel tank sender sock/strainer.
To test - take a glass jar and disconnect the fuel line after fuel pump (at carburetor is a great location) and see how much fuel is pumped in a certain time frame (fuel volume test). This works for testing volume on mechanical and electric pumps. I do not have the specifications at work.
The more fuel pumped, the better.
Don't quote me on this, but I am thinking 1 quart (liter) in 30-seconds
My '77 wagon currently has a mostly restricted/clogged fuel tank sock/strainer. My plans to change to a newer trunk pan and (newer) fuel tank assembly.
If I take off, wide-open throttle from a stop, my car will die from lack of fuel just before it shifts into second gear. If I keep it in gear, the fuel pump will refill the carburetor bowl after a few (several) seconds, then car will then take-off hard again. Otherwise, car runs great.
I am guessing rust from inside of tank might have flaked off, stopping up that sock.
It's probably the sock in the tank like BudW said.
But you can check two other things before going to all that trouble-
Check the float adjustment for your carburetor, it could be set too low.
Or your idle is set low enough and the power steering pump is acting up, so the engine stalls from a stop when trying to accelerate while turning the wheel left.
Phew, the tank... Worst.
I don't think its the power steering, as the engine acts up like 100yds after being straight again.
Will check carb level, of course. And the sock is most likely still original...
Thanks so far, guys. Will keep you posted.
Ignition wouldn't be an issue unless it's a bad connection or wire that's loosing its power when it jiggles around.
You could verify or rule out the sender by running it off a gas can. I'd it does that with no problems you know you've found the issue.
This might be a quick method to find out, as well.
Removing the fuel line to the carburetor and running a fuel volume test might take just as long.
The results of either test (runs fine with a gas can (or not) or fuel volume test is good (or low volume), will tell you if you have a fuel supply issue (or not). If failed test, then pinpointing the problem will require more testing and most likely require removing tank or sending unit.
That's all perfect advice, thanks guys. I'll first try the volume test and further test this while the driver side is lifted by a jack, simulating a left turn. Maybe I then test with a clear fuel line looped outside the hood to see 'no fuel' in any driving condition. And I'll have a peek inside the tank with a camera.
Will report back, but other project necessities (e.g. new solar panels on my RV - because my wife will complain on vacation in 3 weeks with no power) get the fuel issue slightly delayed....
