10 sec 440 71 Demon Drag Car, 18ft. Dovetail Trailer, Truck
Alleyoop2
Wisconsin
The car is really consistent, I have time slips to prove it. Anyways here is some info on the stuff.
The car: 71 Dodge Demon Drag car . 10.56 Best 1/4, consistent mid 70's
Strong .30 over 67 Steel Crank Pump Gas 440
Fresh Racing 727
489 83/4 410 Spool Moser Axles
10.5-1 Ross Pistons
>525 Comp Cam with 1.6 Rockers
2 inch Super Comp Ceramic Headers
New Q-A1 Adjustable Shocks on all 4 corners
SFI Balancer and Flexplate,
New in the Box Tranny Blanket
4500 Stall converter (Dynamic)
Auto Meter gauges, VDO memory tach w/ shift light
8 gal. fuel cell
MSD 6al-2, Two step
2 Optima Yellow Tops
The Trailer bought new in 2009, used very little
• 83" X 18' w/dovetail Road Warrior®
Weight Rating: 7,000 LBS. GVWR
Axles: Dexter axles, 1-3,500# idler, 1-3,500# electric brake, w/ez-lube, safety breakaway w/charger
Tires & Wheels: ST205/75 D15 load range C tires, 5x5 bolt pattern
Hitch: 2" 7,000# Bulldog w/safety chains
Jack: 2,000# setback, topwind
Ramps: 2X2 tubing (5'long X 18" wide), slides in from rear
Electrical: All required lighting, license bracket w/light, sealed factory wiring harness w/7 way connector
Floor: 2X8 treated yellow pine decking
The Truck: 96 Dodge Ram 2x4 ,360 auto, air, pw, pl, cruise, tranny cooler,
not pretty, but gets the job done! Has a tow package on it. ,auto, pw,pl,ps,pb, cruz,tilt, air works good and so does heat, running boards, rear sliding window, lighted visor over front window, as well as window visors, am/fm radio, inside is clean.
Bought new 5 point harness last spring, so the belts are good for another season. Motor was freshened and gone through in the winter of 2009. And the car was run very limited in the 2010 and 2011 seasons.
I would consider trading just the car? Street cars? Let me know?
Sorry to be long winded, got more pic's if need be.
Anyways, If I were to put a value on the whole package $13,500.00
Located near Hudson, Wisconsin
