4 Spoke Tuff Wheel Horn Button
CMX360
MA
Anyone know how or if a horn button for a 4 spoke tuff wheel comes apart. The foil backed center applique is coming apart on one of mine. I have a NOS applique but how do I get the old one out to put the new one in?! My parts book is no help. The image it gives is way too vague.
DCAspen
ct.
How about a picture,tuff wheels are 3 spoke,not sure what you are trying to fix.
CMX360
MA
In 82 Chrysler replaced the 3 spoke tuff wheel with a new 4 spoke version. It only lasted until 84. It was used in higher end cars and trucks and came in a all black version with black spokes and a bunch of interior colored versions with silver spokes. There were also closed spoke versions which are very rare. Not sure if Chrysler ever officially called it a tuff wheel in any of their literature or manuals but its pretty clear that the wheel was ment to replace the tuff wheel. In my 82 Mirada sales brochure its just called a sport steering wheel.
DCAspen
ct.
It is probably removed from the back of the center cap.
CMX360
MA
No they have a weird design. Looking at them you see no obvious way for it to come apart. I was thinking it might all be glued and you would have to make a real mess out of it to get it apart. It's all right though I got word from a guy on eBay selling one that it's just a tight friction fit. Just have to gently work the pad up from the base and it'll come apart into its 3 pieces. Thanks anyways.
roadrunnerman
n.e. iowa.
that looks close to the wheel i have on my ramcharger.Be carefull prying that off,there is a round "neck" on the backside that has little catch clips to hold the cap on and they break easily.Use finesse and not muscle.
DCAspen
ct.
Does a regular tuff wheel center fit that wheel?
CMX360
MA
Sadly no. However with a little tweaking I think you could do it. The 4 spoke wheel doesn't use the can that the tuff wheel does. Its all part of the wheel. So the piece on the horn button that attaches to the wheel is longer than a tuff wheel because the hole in the center of the wheel is deeper. You could make an adaptor out of metal to make it work. The 4 spoke center can be made to fit a tuff wheel as well (it will lock on but stick up to high) but that means cutting down the inside of the horn button which can't be undone obviously.
Moparguy45
Elsie, Mi
wow i have a all black one in my volare that i found in a car at a junkyard years ago. didnt know that this is the newer version of the tuff wheel that is cool. i have never seen any other cars with them til now
marty mopar
Tempe AZ
The part number for the pads for these wheels starts with
P207
they came in colors and fit 1982-84 4 spoke wheels
I have the following colors NOS
silver
blue (2 shades)
auburn
red
tan
brown 1984 only
all are NOS
the 1984 Daytona and the 1984 truck use
P211 which are stamped with P207 on the back
I have these in
red
charcoal
brown
black
I have these also NOS
All of the above have the fake allen screws on them with a large medallion in the center
I have a feeling all of them are the same casting with different colors
bremereric
FMJ Body Moderator
Jackson Missouri
P207
silver
blue (2 shades)
auburn
red
tan
brown 1984 only
all are NOS
I have these in
red
charcoal
brown
black
Mam oh man Marty has been like a busy bee today.
efriedrich
Marty, you have blue four spoke tuff wheels, any pics, how much?
marty mopar
Tempe AZ
the wheels all start with the following codes for the 4 spoke wheels and then followed by the various color codes.
1982:
P055AB2 blue
P055AC7 dark blue
P055AF5 green
P055AM6 red
P055AT6 tan
P055AA7 silver
P055AH9 auburn
1983:
P063AC7 blue
P063AM6 red
P063BT8 sable brown
P063AA7 silver
1984:
P071CX9 black
P071CM5 red
P071CT9 brown
P071CS8 charcoal
or from the 82 book:
P055 AB2 1 P,D,V,C WHEEL, Strg. w/4 Spoke, Blue
P055 AC7 1 Blue
P055 AF5 1 Green
P055 AM6 1 Red
P055 AT6 1 Tan
P055 AA7 1 Silver
P055 AH9 1 Auburn
2 #P207 AB2 1 P,D,V,C PAD, Strg. Wheel Horn, Blue
P207 AC7 1 Blue
P207 AF5 1 Green
P207 AM6 1 Red
P207 AT6 1 Tan
P207 AA7 1 Silver
P207 AH9 1 Auburn
3 4221 016 1 SWITCH, Horn
4 3747 899 1 CAM, Turn Signal Cancelling
5 #4188 643 1 ORNAMENT, Strg. Wheel Horn Pad
6 #P201 AB2 1 P,D,V,C SHROUD, Strg. Wheel Hub, Blue
P201 AC9 1 Blue
P201 AF5 1 Green
P201 AM6 1 Red
P201 AT6 1 Tan
P201 AA7 1 Silver
P201 AH9 1 Auburn
THE 1983 BOOK:
#P063 AC7 1 WHEEL, Strg. w/4 Spoke, Blue
P063 AM6 1 Red
P063 BT8 1 Sable Brown
P063 AA7 1 Silver
2 #P207 AC7 1 PAD, Strg. Wheel Horn, Blue
P207 AM6 1 Red
P207 BT8 1 Sable Brown
P207 AA7 1 Silver
4147 010 1 SWITCH, w/Damper, w/Auto Trans.
5 1 ORNAMENT, Strg. Wheel Horn Pad (Serv. In Item 2)
6 #P201 AC9 1 SHROUD, Strg. Wheel Hub, Blue
P201 AM6 1 Red
P201 BT8 1 Tan
P201 AA7 1 Silver
STEERING WHEEL 4 SPOKE SPORT P,D,V,C,X,S,E,T
Figure 19-400
THE 1984 BOOK:
0P071CX9 1 WHEEL, Strg. w/4 Spoke, Black
0P071CM5 1 Red
0P071CT9 1 Brown
0P071CS9 1 Charcoal
2 0P211CX9 1 PAD, Strg. Wheel Horn, Black
0P211CM6 1 Red
0P211CT8 1 Brown
0P211CS8 1 Charcoal
3 04221016 1 SWITCH, Horn
04147010 1 SWITCH, w/Damper, w/Auto Trans.
4 03747
5 06500126 1 NUT, Strg. Whl.
6 0P201CX9 1 SHROUD, Strg. Wheel Hub, Black
0P201AM6 1 Red
0P201BT8 1 Brown
0P201CS8 1 Charcoal
jbergmopes
Marty...you still have any of those center caps. I have a budy with a 4X8 water jet cutter says he can make all the tuff wheel blanks we can buy. Inerested, anyone?!!
