beatersRus
so ive been mocking up the build on my 81,
using a 318 magnum and have finally gotten a 360 magnum motor.
i think im in the home stretch to finally getting this car/combo together.
my questions would be,what mounts did you use to install,
currently,i have the 318 magnum in there on v8 mounts cut from another k frame.
and what oil pan AND oil pan pickup did you use?
is it Baffled or open?
do you have a link to where i can buy both?
i was reading about dakota oil pans.
is that a viable solution?
DODGE DAKOTA Dorman Oil Pans 264-233
