'76-'77 Volare Finish Panel Mounting Brackets -- PN 4057568
Jared Jordan
Bakersfield, CA
Looking to buy a pair of the plastic finish panel mounting brackets, PN 4057568, for a '76 or '77 Volare.
I've got two finish panels and had brackets. Don't know where they disappeared to. Hoping I might get lucky and avoid scouring the local salvage yards.
Hey....welcome aboard Jared!
Hopefully someone here can help you out.
What's your location?
I flew in a call to National Moparts....
He's looking....I punched that number up at Marty's and nothing came up
Are those actual brackets or clips?
Jared Jordan
Bakersfield, CA
Thanks! I really appreciate that! It's two little plastic mounting brackets that slide into the rails on the backside of the finish panel. They've got studs on them that go through the rear body panel so the finish panel can be secured from the inside. I've got all the stuff to change the car from a '78-'79 to a '76-'77 for NHRA Stock Eliminator, but I'm missing those!
I had a pair once. Don't know what happened to them. If I recall, they were brittle and broke in half. I've only run the car as a '77 one time and when I changed it back to '79, took all the '77 stuff out, and I think it happened at that time.
I'll let you know what they say when I hear from them.
Fingers crossed....
Did you try F body Jim over on the Aspen site yet?
I'd definitely throw an ad up there too..
Holy crap man....not an easy part to find is it?
I'm waiting on National Moparts and I've got one number to try tomorrow that I got from collector's auto supply.
I'll let you know....
alf44
southern MN
illlook in my pile o parts as i took mine off n filled in the holes,, if i find em in good shape you can have em for the shipping. give me a day or so to look ok?
alf44
southern MN
the 76-77 finish panel was the metal one, am i right? i re read your add better and you are looking for the brackets for the plastic panel , i think i have brackets for both but dont put that in stone as ill look ;)
You'll have to wait for the final word from Jared
But as far as I know...yes it's the metal finish panel.
alf44
southern MN
ok,i got screwed up,, long day at work,lol i found my plastic plymouth panel with thje mounts attached to plastic but havent found the metal one yet, probly burried ;(
alf44
southern MN
still looking, off work this weekend so i can be in garage longer to look, but if you find em anywhere else dont wait on me jared.
NoCar340
Upper MI
Have you got a picture of these? I don't have any on hand, I'm sure of that, but I can definitely keep my eyes open. If you can get a picture with dimensions (next to a tape measure) I may be able to source a functional replacement. It's not like anyone's going to see them, correct?
alf44
southern MN
trim panel bracket
this might be what u r looking for? small pic i know but all i got
NoCar340
Upper MI
That's half the size of a postage stamp. I can't even see what it is with my bifocals!
Jared Jordan
Bakersfield, CA
Still no luck. I can take some measurements if need be. I'd need to take the tail lights out of it to measure the center-to-center distance for the studs. Won't be able to do that until after Mopars at the Strip next weekend.
