WANTED '84 and up wiper linkage
M_Body_Coupe
Windsor, ON, Canada
I'm looking for the complete wiper linkage assembly (everything between the wiper arm motor and wiper arm itself) from a M-body years '84 onwards. Basically, if the parts/donor car has the wiper motor which is at 90-deg angle and does NOT protrude out into the engine bay, but instead tucks-in into a firewall "dimple", that car will have the parts I'm looking for.
Thanks!
PM sent,Did you change the wiper parts to the later year set up?
...Did you change the wiper parts to the later year set up?
I changed the wiper motor ONLY from my '80 to about '84-upwards model year. I found out the linkage between the short motor arm and the wiper arm pivots appear to be different, or at least the mounting point is machined in a different spot.
Also, got your PM, crafting a response, there is a long list of things....LOL!
I can get stuff of Jessie if you want.
Was at his shop on Tuesday.
OMG!!!
Dr...yeah, of course, if he has something that comes out of the post '84 model year vehicle I am absolutely going to take a stab at it.
Right now my best (only) option is to drill an additional mounting hole for the bushing and even though there will be a bit of an overlap attempt to re-locate the bushing to that spot and hook the linkage back up.
I may actually just do that since I simply want the linkage to be completed and usable, but as you know, I never have the ride out there in the rain anyways, so I wasn't kidding in the other thread when I said I have never actually used the wipers since I put the darn thing back on the road!
Yes, hook me up pls!
That motor was for 88/89 Caravelle, because that's all the M's he had.
Dr.,
I restored one of them, but given the problem I had ran into I found out that from about mid-year '84 Mopar apparently went to this style of wiper motor on the M-body cars.
So...if he has the linkage to match that particular motor that is a GO for me...it will fit!
