84 LeBaron Convertible - $650 Austin TX
And for the Convertible lovers out there:
LeBaron Convertible, ClassicK Car Body, 2.2l Turbo, 4 cylinder
Add says:
Everything about the Body is 100%
Engine has a cylinder 4 misfire, possibly due to a faulty fan clutch sensor causing an overheat. These cars idle high, that's just their character. This problem with the fan not coming on while idling is very common and there is a workaround and a fix for the issue.
Needs engine rings replaced for the cylinder #4. The car burns about a quart of oil for every 100 miles driven. Odometer reads 47,XXX because they don't go over 100,XXX.
This is a badass car that is very fixable. Easy to work on, easy engine access. Parts are cheap. Good base for a project
Driving to Austin in the summer... ouch.
JW
