A/C help?
Bryan M.
Kentucky
I'm trying to get the Imperial's A/C functioning. I've got cold air, but I need to move it through the dash instead of freezing my feet while I sweat my arse off. I've found that the two vacuum lines under the hood have been cooked through and that there is no terminal end for either one. I need to know where they go. The break-through spot is under the wiper motor, near the accelerator cable. One white/clear and one black line. I can get pictures if that will help.
Cordoba1
Northern Illinois
One should get supply vacuum from the manifold, the other should feed the water-control valve on the passenger side of the engine compartment. I believe black goes to the water control valve. Swap them if that doesn't work.
