aftermarket stereo
/6Volare
Manitoba, Canada
Hi everyone.
I just joined as my son picked up a 77 Volare for his first car. Slant 6, auto, 2 door. Only 65000 km. Runs great but the body needs a bit of work.
Anyway, he wants to put in a new stereo. AM radio doesn't do it for him. I've never dealt much with Mopar products and from looking at the dash it seems that an adapter plate of dome sort is needed.
Any suggestions? The am/fm unit will be a modern pioneer system with 6x9s in the back.
Thanks
Jeff
Welcome aboard!
Hopefully some of out gurus will chime in.
I always use Chrysler radios so I don't have a clue how to install new ones.
/6Volare
Manitoba, Canada
Thanks for the welcome.
Basically he wants fm. Would it be simpler to find a stock radio and install that? Would be nice to have an aux input and bluetooth
pretty simple with the adapter. The dash adapter is a few bucks for a din and a half hole. Also the plug adapter may work it easier, but the early plug in the 77's harness does not have a constant "on" 12 volts for new radio memory. You will need to splice the cigarette lighter's 12 volt leg (to the center of the barrel). The Volare dash is not real deep so steer clear of an aftermarket radio with a deep profile or cooling fins for an internal amp. Otherwise the radio will be sticking out. Any mopar radio from 76 Volares to 97 rams will take the same dash adapter. The plug harness is only needed if you don't want to splice.
Now if you want to get clever, gut the AM chassis and put in a modern MP/SAT unit using the factory AM housing. Again, some mild fab
/6Volare
Manitoba, Canada
Thanks for the info. So if I understand correctly I can use any 76 to 97 radio or is just the same adapter?
Jeff
Yep, you could slap a radio out of a 94 to 97 ram or van in there CD dash type.
The plugs changed around 81ish?
If it was a later model you could just plug and play a newer Dakota CD/Cassette unit in.
The older ones have a different plug setup.
But they mount exactly the same in the dash.
I vaguely remember a converter kit from Walmart you could buy.
The mounting pattern is identical.
But the wiring is different.
Old.
vs Newer.
/6Volare
Manitoba, Canada
Interesting. Seems it may be easier to find a stock unit at the wrecker and rewire. Any suggestions for speakers? I assume front and rear would be required for the newer units
Thanks.
/6Volare
Manitoba, Canada
Yes. Basic am radio with a single dash speaker. Overall the car is low optioned. Power steering but manual brakes. Slant 6 auto. It was owned by a rural school teacher. It was a second vehicle for her and hubby.
Well your choices are to run new lines and cut holes.
Or buy a new full range 4x10 for the dash.
I have a link for the speaker if you want it.
That's the route I'm going with my Volare.
/6Volare
Manitoba, Canada
Thanks for all the help guys. Ended up going with a single DIN Sony with 6x9's in the back. It has bluetooth as well to allow hsnds free calling. There was factory stampings in the sheet metal including holes for the attachment screes. The underlay was also factory marked where to cut. Worked out very well.
