F body Deconstructor Jim
Left and right rear quarter sections from a 77 Volare Premier wagon. DS should fit all 76-80 Aspen and Volare wagons PS 76-79(the passenger side trunk extension/drop to trunk pan seam is slightly different on 1980 models, but could be used with minor modifications)
Driver side is solid, no rust, just a couple small dings. Includes full 1/4 skin with wheelhouse, rear door jamb/striker panel, rocker end section, tail light housing area and trunk extension/drop still attached $370
Passenger side skin has one small golfball sized hole in lower 1/4(typical F location) and a couple small dents. Includes full 1/4 skin with wheelhouse, rear door jamb/striker panel, rocker end section, tail light housing area and trunk extension/drop still attached $310
These are shippable by Greyhound for somewhere in the $90-$130 range, depending on location. Common carrier will be at least twice that.
pm me here or email Jims_AZ_Parts at cox dot net
ccasion14:
(previous owner spraybombed the car :icon_oak: so panel looks far worse than it really is)
