brake line ?
joeblo
I'm almost done with the brake lines but ran in to a snag. I thought that the line from the front of of the master cylinder ran to the front of the prop valve, and the back to the back. I looked at Erics and saw that his crossed, now I am confused?. Its a 1980 Diplomat that had power brakes, and the master cylinder was replaced with a manual one from a 1979 Roadrunner. Any help would be appriciated.
Thanx Don
jasperjacko
I looked at my 81 doba, and the front fo the master cylinder goes to the top rear of the proportioning valve.
bremereric
FMJ Body Moderator
Jackson Missouri
The master cylinder is the key, power or manual doesn't matter as long as the bigger compartment is in the rear for the front disk brakes.
joeblo
Thanx guys, now if I could just find the line fittings and get some time off work, maybe I could finish the brakes and take this thing for a ride.
jasperjacko
do you need the curly lines from the master cylinder to the prop. valve
joeblo
No, I'll just make some when I get some time.
