Cable kickdown setup
Mopar&vettedude
Tonwanda, ny
Morning. I'm sure this will be a dumb question, but here we go. I was wondering for those that run a street demon and running the lokar kickdown kit, which prevision do you use at the bottom of the throttle linkage? there's three holes, i'm guessing its the center? any info is appreciated.
Center, should keep as close to 6 o’clock to the throttle cable position to ensure they’re moving 1:1.
Didn't think of it like that. Makes sense. Thank you.
No problem. You may have to do a couple hot laps to get the tension for the cable set right. Too loose and it will shift gears way to early, too tight and it will hold gears till your WOT and redline the engine.
