The compression is the issue here.  A stock 80's truck motor is going to have toilet bowl compression.  Probably 8:1 or less.  I wouldn't go any higher than this:
Xtreme Energy 218/224 Hydraulic Roller Cam for Chrysler 273-360
If you can get the compression above 9:1 then consider 224/230 cam.  No higher than that with a factory converter.
If parts get mismatched you'll have an absolute dog.  Learned this the hard way in my early 20's.
As to roller vs flat tappet, I'll never run a flat tappet again.  Machine work on a lot of lifter faces are causing cams to wipe out.  Been a problem for a while.
And you have a block that'll run a roller without having to use expensive retrofit rollers.  Be sure to make sure the springs match and pushrods are the correct length.
