Chrome door trim....
prowler
santa clara CA
My 77 LeBaron has a chrome strip running along the top of each door next to window(2dr coupe). I need to remove passenger side as about in the middle, there is a dent I would like to remove. There's a retaining nut at the rear of strip you can get off with a wrench. The strip, once nut is off, will partially lift off from the rear. There is also an inside lip that fits into a channel. Question is,....is there a front nut that's on the inside requiring door panel removal? I
got it about half way lifted up bit didn't want to force it. Thanks..
