WANTED Cruise Control Stalk
Fresh Air Inspector
Yarmouth, NS, Canada
Hello All,
I'm looking for a cruise control stalk for my '88 Caravelle (aka Gran Fury), like the one in the first picture. The one I'm looking for has a 4 flat pin male connector that plugs into the female connector in second picture (factory wiring harness). I can NOT use the cruise control stalk with a connector like the one in third picture (it uses two male bullet connectors as shown and two female bullet connectors).
Appreciate any feedback you may have.
Hello Stroked408,
Thank you for your email. I'm a little concerned that the control stalk you have is for an earlier series than mine (1988). I base this on the connector in your pictures, it is the style that was used in the '70s. The colour coding does align with the 1988 factory wiring diagram I have; BR/RD, WT, YL/RD and DB/WT (factory diagram shows WT/RD instead of WT on the control) which adds to my confusion. I attached a picture showing the factory colour coding chart.
I have two questions;
1. Do you know what year (which years) of vehicle(s) this control stalk fits (the document indicates June 1980)?
2. Do you own a 'continuity meter' (Ohm meter), to measure which wires are connected as each switch is moved? The picture below shows the factory 'continuity chart'
I will thank you in advance for any 'detective work' you do on my behalf.
Apologies for the delay in getting back to you. I found two other units, but I think this is the one you need. It shows fitting 1987-1990 Chrysler 5th Avenue, LeBaron, New Yorker, TC Masterati, Town & Country, Dodge 600, Aries K.
Hello stroked408,
Yes, the one in the first picture p/n 4373257 is the one I need. Your second one p/n 94013A is the one I remember from the 1970s Chrysler products.
Let me know what you want for p/n 4373257 plus shipping (USPS ground is fine), to postal code B5A 4C3 in Yarmouth, Nova Scotia, Canada. I'll send you a PM tomorrow (Tue), with my complete contact details.
