Diplomat horn
Not sure which side each is on. You may have to look at the horns and see what the hertz is to find out. It'll be molded into the plastic part. The lower number is the low note horn. Can't recall off hand what the hertz are for the various notes though.
ZieglerSpeed
De Graff, Minnesota
Thanks, ok, the drivers side is lo note, pass side is hi. I learned on most if not all the factory horns say hi or lo but you may have to look a while to find especially if dirty
