WANTED Disc brake spindles
The "disk brake" part doesn't matter.
Any FMJ or B/R body after mid-year '73 - which should help open a few options.
The early '73 B-body (and older) has the K-frame bolting straight to the frame rails. The late '73 to '81 B/R-body K-frames have rubber mounts insulating the K-frame to frame rails.
The early '73 B-body and later A-body Spindles look similar to - but the newer spindle upper ball joint flange rests about 1/2 inch higher compared to the older spindles.
I have heard of the older spindles working fine for FMJ's (or vice versa) but you might have a suspension geometry issues (in theory)...maybe.
Junk yards. Tons out there.
Check further down the page here, there's at least one person parting out an M that might have it.
