Aug 21, 2022 #1 M MARCH374 Well-Known Member Joined Jan 28, 2012 Messages 136 Reaction score 27 What advantage's do Drop Spindle have ? Are there any negative's to using them > Thanks
Aug 21, 2022 #2 jasperjacko Well-Known Member Joined Dec 4, 2011 Messages 1,672 Reaction score 251 + lower center of gravity, - ground clearance
Aug 22, 2022 #3 Duke5A Well-Known Member Joined Apr 6, 2018 Messages 1,806 Reaction score 1,014 Location Michigan I wouldn't entertain it on these cars if you have factory torsion bars. You'll bottom the car out driving over even small pot holes. Under steering link headers take enough punishment with a factory ride height.
Aug 22, 2022 #4 Aspen500 Well-Known Member Joined Feb 14, 2015 Messages 7,323 Reaction score 2,971 Location Rib Mountain, WI Advantage is the car is lowered but suspension geometry stays the same. Disadvantage is lower ball joint to wheel clearance in some cases.
Aug 24, 2022 #5 mikedevore Well-Known Member Joined Oct 12, 2011 Messages 142 Reaction score 113 Location Sapulpa, Ok. Where can you get these dropped spindles?
Aug 24, 2022 #6 Duke5A Well-Known Member Joined Apr 6, 2018 Messages 1,806 Reaction score 1,014 Location Michigan MOPAR MIKE said: Where can you get these dropped spindles? Click to expand... DROPPED UPRIGHTS/SPINDLES | Fat Man Fabrications
