83Imp
I'm converting my 83 Imperial from (inop) EFI to carb/elec ignition. I have a new EI distributor and wiring kit, but I need the engine harness to connect the temp sender, oil sender, AC, choke...etc. Any small block should work as long as it has AC. I have a PN from the Imperial conversion literature... not really sure if it crosses to Dodge?
PN referenced is 4209234
Also, on the off chance someone has a carb-converted Imperial parts car with that harness, there is also a seperate overlay harness I need too. Its PN is 4304969.
Thanks, Brad
Thanks, Brad
