F Body VS C Body Spindles
76VRR318
PA
I need some help and expertise!! I picked up a 76 volare drag car and it did have a bunch of mix and match parts. It did come with the larger 11.75 12" front disc brake rotors but no caliper brackets. I ordered a set from DR. Diff that should work on A/B/F body cars but the mounting holes are too narrow. I did some researched and found out the C body cars have a wider mounting bolt pattern for the brake caliper brackets.
So my question is there any issue with running C body spindles on an F body car? Is the height different? Any other differences from the f body spindles other than the mounting bracket bolt hole space?
