I have a complete rear sway bar setup. This includes the frame rail brackets, shock plates, and even hardware. I literally saved everything except the rubber spring insulators (which are the same as what's on your car now anyhow) The studs broke on one of the frame brackets, and the link rods broke off at the threads during removal (don't they always?). Everything's still covered in the copious undercoating applied by the factory, and the bushings actually look suprisingly good. I don't know that I'd reuse 35-year-old ones, but they're not hammered or rotten.
I'm asking $150 for the complete setup as it sits.
For an extra $25 I'll fix the frame bracket's broken studs
For another $25 I'll fix the link rods if you're a stickler for the correct, shouldered originals.
Want it all cleaned up, blasted and painted? Add yet another $50. That's a lot of work!
If you want more pictures, PM me or respond here.
