Ignition box
Advertised better than MSD and it is plug and play:
http://thertgarage.com/
Rev adjustable and those 7 LEDs are actually a tach for underhood tuning
And if you have a five pin car with a dual ballast system?
I asked that too of the manufacturer. I would think yes. I run a 5 wire set up on a 4 pin box. The harness sometimes gets a wire flipped on the 5 wire harness to work a 4 pin box. So the harness is the question or unknown variable here. I believe my harness is not modified. Damn I need cash, b/c I want to try that box.
Just got confirmation from Lara- OEM rep for this. The box will run 5 wire mopars too. HELL YEAH!
gtsdude
SE MN
http://www.4secondsflat.com/
Don at FBO has same type of deal, only you can get rid of the ballast resistor with his set up. I have his old set up on my 68. I have heard good things about the revanator also.
