In search of a Thermoquad SIS (Solenoid Idle Stop) for A/C operation at idle.
8v-of-fury
Orillia, Ontario
When I converted the engine from lean burn I got rid of the two barrel and cast intake in favour of an aluminum Edelbrock and 850cfm TQ.
The old 2 barrell had a solenoid that kicked the idle up when you turned the air conditioning on, and this new carb does not have one. I still have the wiring on the engine for what ever would be needed, so i think it should be as easy as adding an SIS to this carburetor.
Unless there is some other method for running A/C on a carb with no idle kick solenoid? :D
