SOLD Last call...
NoCar340
Upper MI
Since I got my Challenger home and still have the Imperial inbound, I simply do not have room to hang onto the M-body & other miscellaneous stuff I have lying around anymore. I just havent' got the space and I don't want to be tripping over it anymore. They don't make this stuff anymore. Perhaps someone close enough with a pickup would like to make a lowball offer on everything and resell it themselves, but I have to get it out of my way. So, unless someone wants it everything is going to either the dump or the scrap-metal place down the street. I hate to do it because there's some good stuff here and parts for these cars can be very hard to find. I will accept reasonable offers on any/all of it. Don't be shy.
All parts located in Kingsford, MI, ZIP 49802. They may ship from 54121, where I work. If I can ship it, I will. If I can't, it will be noted as such. Shipping is not included in any of the prices. I can hang onto something for you if you've paid, but I'm not going to stumble over a fender for two months over $20 either.
So, here goes... with photos:
1980-81 M-body coupe LH inner rear trim panel, green. Armrest is mildew-stained and trim panel needs to be reglued. Comes with matching trim panel for RH side, as well as the RH armrest if I can find it. $25, will not ship
LH & RH fenders, M-body & 1980 F-body (marker lamp hole may need covering or modification, fascia fastener holes vary by year). $50 each or take the pair for $80. I cannot ship these.
LH fender is in original Baron Red paint. Surface rust only, no filler, pinholes or dents. Free marker lamp!
RH fender is painted on the exterior with Chassis Saver, inside is original. Surface rust only, no filler or pinholes. There is a very-minor unstretched dent above the wheel opening I can't get to appear in photos.
F/M hood latch support. Definitely fits all '80 up, not sure of earlier cars (I think it's the same back to '77 on the M-bodies). Rust free, with latch, latch plate, and horns. $35. This can be shipped.
FMJ washer bottle with cap & pump. Dirty but not fragile or brittle. Pump worked when pulled; stored indoors but no gaurantee the pump still works (though I bet it does). $20.
M-body (F? J?) radiator overflow bottle. Again, dirty but in excellent physical shape. May fit F & J as well, it's up to you to verify. $20. Shippable.
FMJ original transmission cooler lines for A904/998/999. Both lines 100% unmolested, still held together by factory clips, with the factory reverse-inverted-flare nuts in good shape. $20, not worth the cost to ship UPS Oversize but if you gotta have 'em I can work it out after you faint at the price of that.
1980-up F/M column-shift automatic steering column. All switches present, no damage to connectors or wiring. Delay wiper switch. No slop in bearings whatsoever. Good shift indicator needle. I have the key for the ignition somewhere and will dig it out and include it. No lower half (below rag joint). Steering wheel is not included, nor is it for sale. $25, shippable.
To be continued...
NoCar340
Upper MI
F/M wiper arms, factory black. Need repaint. Excellent splines and latching mechanisms, posts in great shape. $20 for both, shippable.
M-body LH front wheel opening moulding. Very nice shape, not bend or banged up. $20, cannot ship reasonably.
F/M/J cold-air intake duct. Runs from LH side of radiator bulkhead to inner fender, air-cleaner hose connects to it there. Includes cover at core-support end and inner fender mounting flange w/original screw. I no longer have the hose. $15, shippable.
'80-up steering column switches. Includes turn signal, delay wiper, and cruise switches. All work perfectly and have excellent wiring. I do not have the small screws that hold the cruise switch over the stalk. $30 for all three, shippable.
1980-81 M-body rear interior panels, red. Trim panels and armrests present & in good shape. One panel is broken near the door sill area but I have the missing piece to repair it. $60 for the pair, I will not separate them. Cannot be shipped.
I also have the 1980 LeBaron Medallion grille listed here. $75, will ship.
FAIR WARNING: Anything not spoken for or in negotiation by 11:00 PM MAY 30TH 2014 will be discarded by 8AM May 31st.
After that, this thread will be marked SOLD in the title and questions like "do you still have" will go unanswered because I won't.
