88fury
So the original starter finally gave up. Found a 98 Dakota new on marketplace for 30 bucks. The more I took apart the more problems I have. Wire harness fell apart. I’ve remade the harness now. Both mounting bolts / studs were stuck and needed an impact to get them off. Waiting on a thread chaser to come in to clean them up. The stud came out when I tried to get the nut off. Since life happens and simple projects take way more time then thought I can’t remember if the stud was on top or bottom. I want to say bottom from the service manual pictures I have but I’m not sure. The stud it self is in ruff shape anyone use just bolts or have a source for a new stud ? Thank you in advance for your time.
