Mopar Performance Small Block Electronic Ingnition Conversion Kit p/n 3690426
NoCar340
Upper MI
This carburetor is not a double pumper. It's a dual inlet ("dual feed"), vacuum secondary carburetor with one accelerator pump. It is a "single pumper" as is every 3310 ever built. Dual inlets do not mean double pumper, and double pumpers have been made with single fuel inlets. I'm not bashing on you, just making you aware of one of the most common mistakes people seem to make regarding Holley four-barrel carbs. If it has the big pod on the passenger's side rear, it is without a doubt a model with a single accelerator pump.
Good luck with your auctions!
