dkamp
I have a 318 with a two wire Distributor without points. I'm currently running the Mopar ignition (4 wire Orange Box, 1 Ballast resistor, and factory Oil filled coil).
I want to change to a GM HEI system with no Ballast, but have a few stumbling blocks that I need to overcome first.
If I go to a Junk Yard and locate a 85-95 Chevy S10 and take the 4 pin E-Core coil, and the HEI module (ACDelco D-1906 (4 Pin)), all the needed wire connectors and the coil wire, then make all the correct wiring.
Is the Donor truck OK to use or can you suggest a coil HEI combo that is better?
Please offer a few Make/Model/Year donor vehicles.
Or quote E-core coil and HEI part numbers.
If I can only find an 8 pin HEI module, can I just only use the 4 wires like the D-1906? using this diagram?
Thank You DKamp
Thank You DKamp
