Deano
I could be cruising along, car is running fine, and then it seems to die. Only thing is, it doesn't lose spark. Feels like putting the car in neutral. Doesn't rev. It always "starts" back up, but I don't have to restart it. Is everyone thoroughly confused yet? I know I am. This weekend was the Hot Rod Reunion at Beech Bend and I had planned to drive it, but the route I take has several hills and curves, so I decided not to in case it up and quits on me.
I believe that I used to have the same problem my old '79. I would go through a ballast resistor once every three or four months. The engine would run as long as I had the starter engaged. Second I let off, it would die. A mechanic friend from school finally figured it out. When whoever converted the Lean Burn to electronic ignition, they didn't swap out the coil. He told me that there's a difference between the two. After he switched them out, the engine would start immediately. Six or seven months later, I totalled it.
Could this be my problem? I don't really know how to describe it thoroughly, to where anyone knows what I'm talking about.
