bremereric
FMJ Body Moderator
Reilly Motor Sports offers a complete coil over front end and k member for our cars...lots of dough...but I know of two people that have installed them and love them...
AlterKtion Coil-Over System, Street/Handling, 76-89 F,J,M-body
Our complete suspension systems do more than save weight and add clearance. They're designed with precise geometry for optimum control, whether you're on the road course,
cruising along winding country roads, or driving along pothole-covered city streets.
Durability is second to none with these systems, and they've been tested tough for years
in everything from daily drivers, road courses, and 7-second dedicated strip cars.
Easy to install and work with, the Alterktion system bolts up to factory frame rails, and as such, is
accepted in many classes where other suspension kits are not.
Brake kits are widely available, so if you don't want to use the Wilwood kits we carry, you
can easily choose your own brake kit from any manufacturer.
System comes complete from connection to your steering column, down to the spindles
and includes complete 1-1/16" sway bar package, custom valved power steering rack, and hoses
that will connect to your factory power steering pump.
Engine mount options include complete mounts to block, all are poly bushed spool-type mounts.
Simply add a brake kit to build a complete suspension system.
For more detailed information and photos, see the Tech Pages, and Gallery sections.
Pictured with optional Hemi engine mounts Details
Weight132.00 lbs Price:$4,295.00
