Replacing Tail Light/Brake Light bulb sockets
LSM360
Melbourne, Florida
I've replaced my Tail/Brake Light sockets once before on my '89 Diplomat a long time ago with some OEM ones. Despite the car staying dry, these OEM ones are problematic and often take some wiggling for them to come back on. I THINK it's usually a problem with the way they ground.
I'm wondering if anyone has found a later OEM Mopar lamp socket that will twist and lock in to an M Body tail lamp housing. I see some NOS ones on Feebay that look similar (insert and twist to lock) but I can't tell if they will actually fit. Most are now LED which is fine (probably better anyway). I'm not looking to swap out for sequential. Just a better option than stock.
Thanks,
Larry
I used K car sockets. I pulled a harness out of a K Lebaron and converted to the M body by adding a ground.
I would imagine the K car socket from same era may present some of the same reliability issues. Strange, because my '89 parts catalog shows part number 4450815 for rear tail/stop lamp socket but when I look up that number it's the metal one used for rear side marker.
Mine came out of an 84 Lebaron in a junkyard. I think it was an 84. My car spent most of its life in Idaho/Utah/Arizona, so all the plastics were destroyed including the tail sockets But in NY that stuff survives while the sheet metal rots.
I haven't had an issue since.
The Cherry Bomb's taillight wiring started shorting out everywhere, ended up putting an '87 Fifth Avenue wiring harness on, one of the taillights didn't work so I cut the only socket that still worked and spliced it in place, I haven't had an issue since, I also had to modify the license plate light to work with the single bulb Fury's and Diplomats have
I've been up in my attic trying to organize the huge amount of stuff I have up there, mostly car stuff but other stuff too. Well I'll be dipped (thanks Derek). I found several used ones I had up there so I'll see if they work. This is the problem with never having enough time and just putting stuff up there in a hurry because no time to catalog it all and then forgetting what's been up there for twenty-something years.
