slant six
- Joined
- Nov 30, 2014
- Messages
- 154
- Reaction score
- 70
I have some parts left from a '79 Volare' Coupe that I have mostly Parted.
If anyone is interested in these parts please respond, otherwise They will go to the scrap pile, and get cut with no regard for saving the parts.
I can remove parts properly with a minimal amount of damage using a spot weld cutter for you.
All are located in 15642, PA ~ 5 Min from I76, Exit 67 in PA. Can bring large pieces to shows that I usually attend (Mason Dixon Dragway in May 2026, Albion, PA in June 2026, Carlisle in July 2026.
Front Core support $100
Solid, no smashes or collisions, some rot near spot welds under the batt. tray area and also near the right side front under the overflow can / vapor canister area. I feel that if you can work with metal and a mig welder / grinder these are easy repairs. Part is not perfect but good and usable. more pictures upon request.
Left and Right Inner Fenders $40 Each - I cut these from the frame rail so there is ~1/2" of metal missing where they were welded from the factory that will need replaced.
RIGHT:
LEFT:
Front Floor Section $100.
It is not perfect. There is some rust above the rails, but is 92% solid.
I would be cutting all the spotwelds to remove this piece.
If I did not list it here, that is because it is sold or rusty garbage.
Thank you.
RIGHT:
LEFT:
Thank you.
