- Joined
- Dec 21, 2011
- Messages
- 2,978
- Reaction score
- 697
So I've been getting a sputter and a slight miss at times at idle. My winter tune was not the greatest, spring tune was completely off.
So I pulled one spark plug at a time. No1 & 3 black carbon. Same 2 & 4. Those are the front 4. The back four: No 5,7, 6,8 were a slight brown with a hint white. Plugs only have a about 1000 miles on them. I cleaned them up and put everything back. I checked the cap and rotor, them too were in very good shape- I've seen worse on my magnum engines. So I started the engine and was bringing some timing into the engine (turning counterclockwise or what is also called advancing the timing) After I shut the engine off she would not start. Way too much timing. I backed it off and got it to start and then back to setting timing. I also put some leaning in the idle mix.
So to give a bit of background: The motor is a 1985 Diplomat AHB 318 with a 30 over bore. Intake and heads are off a 70/71 cuda 340 4BBL. The carb is a Edelbrock performer 750 with the E choke kit. I'm back to running the mopar orange ignition and I don't have lean burn. Distributor is a stock mopar vac advance type.
I took it back out for a blast before the rain last night and she is almost good to perfect. Broke the tires loose and pulled hard through the gears up to about 85....... (oh yeah I mean kmh- HAHAHA) Seriously. She had power, but I noticed the idle was higher after the romp'n. I have suspicion that I might be getting timing chain stretching. The dude who threw the engine together put a summit racing cam 218/228 duration and 441 lift, but I question what chain he used. I would think no-one is that lazy to reuse a timing chain and gears when changing a cam. Chain and gears are a cheap insurance. So I will tear the engine down if and when she fails. Until then I'll keep on with my 360 build.
I get a lot of folks telling me the 750 is too big. The car had a 650 cfm holley and it was not enough. The 750 has never bogged out on me. Even when I thought she was leaning out on me at highway speeds, it was not all too bad.
I've never seen a mopar chain stretch. I've seen them destroy the timing gear and pistons kiss the valves. Do they stretch? Does the idle rising seem like the symptoms off chain / timing movement?
