Where is the buzzer hidden on a F body?
I'm looking to eliminate the buzzer than comes on at engine starts and last for about 30 seconds (or less). I think it might be a seatbelt warning or something. Actually, if I locate the timer/ relay that controls that buzzer, I could disconnect the buzzer and wire in the electric fan. That is when the buzzer stops the fan would come on.
So where under the dash might I find this little buzzer?
Aspen360
Lehigh Valley Pa
Open the fuse access panel below the wiper and headlight switches. On the same fuse panel, to the right of the bank of 12 fuses are a cluster of relays and buzzers, the buzzer should be the small rectangle one to the far right bottom.
roadrunnerman
n.e. iowa.
i thought that was supposed to be "top secret" info so nobody was to know where they were located as to drive the general public insane.
