Wire colors needed for radio
Dapert
Richmond, TX
Previous owner cut the factory harness at some point and I only have loose wires in the radio hole with tape on the ends. I did a google search on it and the colors listed dont match what I have. I bought a Metra harness to plug into a factory radio just so I have a harness in there again to use with a factory radio or with another harness and an after market one.
Looking to see if anybody has a pic of their uncut harness. I see a red wire. A yellow. A black/white, a red/blue, and a black/yellow. All the data I found on the web said Red (constant), Red/White (accessory), Orange (dimmer), Yellow (antenna) should be there but obviously that doesn't match what I have.
DCAspen
ct.
What year car are you working on?
This is from my ’86 FSM (Factory Service Manual) – which should be the same for your ’85.
  • 86 FSM pg 8-224.pdf
  • 86 FSM pg 8-225.pdf
  • 86 FSM pg 8-226.pdf
  • 86 FSM pg 8-227.pdf
  • 86 FSM pg 8-228.pdf
