77 or 78 FSM wiring diagram
Remow2112
Need pics of the pages with the ignition switch and through firewall to starter relay.
Thanks all!
well now, I've been gone all day (the Mister to a Pulmonary Function Test today).
Let me get caught up and I'll go through my manual to see what I can find.
Have you already searched the forums for this topic?
Remow2112
Those are some help. But the issue is I want to change my 76 ignition switch (very similar to a 76 A body) to a 77 and up ignition switch. These are the ones that the connector is a half moon shape. The number of wires does not match LOL.
Using a mish mash of my Haynes manual and a 76 FSM I am pretty sure yellow to yellow and heavy red to heavy red should get it to turn over. But I am unclear if that will feed the coil or if the dark blue is need to feed the coil. I am using a Pertronix HEI module for ignition box.
76 connector
77 Connector
Remow2112
I have searched the forum and google all the internet. I have not found exactly what I need. A lot of stuff on the early style connector. Not so much on the 77 and up. :)
Dark blue is the switched ignition power anything that needs power in the "run" position needs that.
