Battery suggestions for F body big block swap
77rod
Hey guys! Hope everyone has had a great summer! It’s been super warm by me, but cooler temps are around the corner. My current battery in my 77 aspen with the 383 big block just took a dump on me. It was a flooded type interstate battery with 810 CCA. That particular battery was a Costco special……I was never super impressed with it. However, I have true interstate batteries from actual interstate battery dealers in my daily vehicles and have been impressed with them. My big question is do I stick with an interstate flooded type battery direct from interstate, or do I go with a red/yellow top optima AGM? I’ve heard good things about the XS power batteries, but they are pricey (400-500 bucks). What’s everyone running these days? Thanks in advance for all of the suggestions! Picture of my ride for attention!
volare 1977
May be better selections nowadays but in the past I always went to battery warehouse and got the best battery they had that would fit in my battery tray. I also had used the red top optima batteries in the past and the newer ones don`t seem to be as good as the older ones.
I had the Optima RedTop (Group 34, CA=100, CCA=800, RC=100) in my Coupe for about 11 yrs...that took me through all the start-ups, tuning events, etc...point being: plenty of cranking going on. That thing was $200 back in 2012.
That battery was replaced ONLY because one of the battery posts developed a crack and eventually split right off. For all I know it could have been me, maybe hitting it somehow, etc...the post break actually was located in the plastic case, weird looking, like a crack through the post actually. I had actually emailed Optima the photos asking for a discount on a replacement battery (seeing as this one was still holding charge, no issues otherwise), but sadly I did not get a response.
I replaced it with another RedTop, same specs as the previous one. The new one cost me $350 in 2023.
After having problems with multiple Costco batteries, International and a bunch of others I've been using Walmart batteries and never had a problem. The oldest is 8 years old, just got one for my Crown Vic a couple weeks ago and will be buying an M body size one any day now.
One huge plus is if there is a problem it's more convenient to deal with then a lot of other places.
I used to run optima batteries in my Panthers and other Fords. Honestly, they're not worth it for a street car. I have Advance Auto and Autozone batteries that have lasted longer. And I used optima when they were still considered "good" batteries.
If you want to be really cheap, and like rolling the dice, buy the $70 Autozone batteries that only come with a 90 day warranty. They're the same batteries that come with 2 year warranties that cost twice or three times as much. The "warranty" is just you pre paying for a replacement. Autozone doesn't keep the cheapo batteries on the customer facing shelves; they keep them in the back. The last time I bought one the goofball behind the counter tried to shame me into buying a more expensive battery. Didn't work.
Also, the local junkyards by me sell used, tested, batteries for $35. For $2 more you can get a junkyard exchange warranty.
69-
Germany
Batteries die. Someday. And you never know when, no matter what brand. I go for cheapos that fit in height and pole's position.
77rod
Thanks everyone for all of the great responses! I am leaning towards the optima as of right now, but also not against an interstate either. Thanks again!
77rod
Thank you for the advice! I am currently considering a yellow top optima battery because of your good luck with optima. I may go with a red top but trying to figure out what size I should go with in general.
I don't even know what's in the Fifth. It's an 800cca something. I think it's a name brand. It's seven years old now. My F150 has a no name in it that went dead from not being used. Shocked it back to life with a stick welder and it's been fine for three years now.
I only pay around $200 for a battery. Suited me well so far.
77rod
Hey Guys! I just wanted to update to the post and let everyone know that I ended up going with a group 27 840 CCA Duracell brand battery from batteries plus. I found a decent number of good reviews on them, so I figured I would give it a shot. I've got an interstate (from an intestate store, not from a big box) in my 2013 Camry, so it will be interesting to see which one seems to be better. Thanks everyone for the great feedback!
69-
Germany
200 bucks for a battery?? :oops:
I just got a new one for my Charger (70Ah, dunno CCA) for 75 EUR/approx 90 USD incl shipping...
And I thought those are more expensive over here in Europe...
69-
Germany
And properly tighten the screws...
Otherwise:
Happened a friend yesterday with his racer Valiant.
